I've tried "sponging" pb blaster under the bolt heads hoping that some will seep in. Today my L-shaped torx tool from Nashbar came in and was hoping the extra leverage would help. Well, ended up rounding two bolts that will now require some unconventional method to get out. I like the idea of cutting a line across the bolt head so that you could use a flathead screwdriver. But what tools do I use for doing that? Don't have a dremel. I don't want to damage my wheel or rotor trying to cut the bolt. I figure I only need to loosen one of the two, and once I get one of the bolts off I can simply rotate the rotor to loosen the last bolt.
I may just take it to the bike shop. Maybe Shimano is onto something with their centerlock. Hmmmm.
