I have a 2019 stumpy that came with sram guide brakes (which I don't like). My mechanic has suggested replacing the stock rotors with a set of 2 piece rotors as they will shed heat better and will perform better, especially at high altitudes where this bike lives most of the year. The issue is the bike has 200/180 rotors, and the sram 2 piece rotors don't seem to come bigger than 180mm (which seems crazy to me). I looked at shimano, and their xtr rotors come in 203mm, not 200mm. Is there an issue using shimano rotors on an otherwise sram brake system, will the 3mm size difference cause problems, and does anyone else make a high end 2 piece rotor in 200/180?
