I'm having a problem getting my 203mm front fork rotor to avoid hitting the internal center of the caliper. I installed an Origin8 Torq-Lite 180mm bracket with stock hardware but the rotor top continues contacting the caliper (not the shoes) unless I apply a few mm gap between the lower bracket and the caliper. I know applying a few small washers are not a safe solution so is it possible that bracket is the problem?
It's installed it correctly (larger spacing up, lower spacing down)
-Cane Creek Helm Coil Fork (fits 180mm rotors stock)
-Origin8 TorQ-Lite 180mm Bracket
-203mm TRP slotted one piece rotor
-Trp Slate T4 Caliper brake
