Judd97, as long as the size is the same, and the braking contact area (where the pads make contact) is as wide or wider than the stock ones you will be fine.
SpecialSSauce, you can upgrade to 180mm but you need to get an adapter for the caliper for the new size.
Cheers,
Cris
