Hi, I'm new here, but I wanted to share a thought experiment I've made.
I wanted to upgrade my wheels, but I just wasn't sure if I could justify spending a bunch of money. So I've set out to quantity how much real world impact to rotational kinetic energy a fancy super light race 1000g (3000 euro) wheelset would make vs just changing the tires for 100$.
A.K.A. How much easier the wheel changes speed or direction for $$$ spent on separate parts of the wheel.
TLDR:
500g (1.1 lbs) wheelset weight reduction makes less of a difference (to rotational kinetic energy) than 150g (0.3 lbs) reduction from tires at 30km/h.
Compared rotational kinetic energy at 15 & 30 KM/h (10 & 20rad/s) (≈ 932 & 18.64 mph) for a 29er wheel (approx. 740mm diam./C=~2.35m):
1) 1440g wheels + 1550g tires
2) 1000g wheels + 1550g tires
3) 1440g wheels + 1400g tires
Bonus:
4) 1440g wheels + 1250g race tires
Calculations and relevant excerpt from wiki:
30km/h:
15km/h:
Findings:
Tires make up the most (~70% in this example) of the kinetic rotational energy of the entire wheel system. And while rims do make make some measurable change - the hubs, spokes, and disc rotors amount to almost nothing.
At 30km/h:
1) 500g of wheelset weight reduction makes just 6% difference of Er from 3KG. At the cost of 3000 euros (~3,410 usd).
2) Only 150g tire weight reduction makes a 7% difference of Er from 3KG. For 100$.
3) Race tires, that drop 300g, make a whopping 14% difference Er from 3KG. For 100$.
Or in other words:
Changing tires can cost as little as ~10usd per 1% of Er savings, but on a wheelset will cost over 500$.
Turns out there is almost 1500 times more rotational kinetic energy difference between a hub and a tire. (Or 1369, to be precise, when calculated a 100g hub weight at 10mm from axis at 20rad/s, I (mom. of inertia) = 0.00001 kg*m², or 0.002 joules, versus 100g @ 370mm = 0.01369 kg*m², or 2.738 joules).
Now I'm not the smartest zergling in the control group, nor am I a physics PhD, nor have I "discovered" something new. We all know that tires have a huge effect on the bike, and that a lighter rim/tire will make the acceleration / decel. and change of direction faster due to less mass moment of inertia. But I was just shocked that a 0.5kg reduced wheel weight made less difference than shaving 150g from tires (not counting the drag).
Clarification:
This is my calculation on the power requirement (joules, or watt per second) to accelerate (and decel.) the wheel. This doesn't mean that on a flat road you will see this, it's probably going to be between wind resistance and tire friction/drag for that.
I would also like to clarify that this isn't bombproof - I'm just an idiot on the internet, and all info is just an estimate. If someone sees an issue with this please correct me.
Would like to know if any of this is what you guys find from experience? Or am I just making a fool out of myself here?
Regards
TLDR:
Bonus:
30km/h:
15km/h:
Findings:
At 30km/h:
Or in other words:
Clarification:
Regards
