1 - 2 of 2 Posts
Wanting to install a roof rack system on my 2014 Subaru Crosstrek XV, and need some guidance to find the correct tray system for both the tire wide 27.5 x 3.0, and the "boost" axle widths 110mm front, and 148mm rear. Thanks for your advice in advance! :thumbsup:
I'm slightly biased and use the Rockymounts Brass knuckles rack for my roof rack. Seems to do the trick and doesn't require removal of the wheel. I haven't been terribly fond of the gas mileage I get with the roof rack but it can even deal with fat bikes if you need it to. The Tomahawk is a cheaper alternative.
Any boost compatible tray mount. The Switch hitter from Rockymounts and Trio from Kuat would work most likely.
I would personally look into hitch solutions though. I just switched to a Kuat Transfer and could not be happier with my decision. No noticeable hit on mileage, and it's far easier to deal with on a day to day basis.
1 - 2 of 2 Posts
