1 - 5 of 5 Posts
Hey guys, coming to you with a two-part question. First, my vehicle (Hummer H3) has slightly curved factory roof racks, and I'd rather not replace them (fitment is a pain in the ass and expensive for this vehicle). Right now, I'm using a Thule Circuit rooftop carrier with an adapter for the Maxle on my MTB. It seems secure up there, but the bike does sit at about a 5-10 degree angle. I can't really move the carrier inboard much, it's a high vehicle. So, is the slant a big concern? I also want to get my road bike up there, so I need another carrier. If one bike leaning at a slight angle is bad, I don't want to do it with two.
Second, I've tried a hitch rack on this thing, but it just doesn't work. Even folded down, the rear door won't open. So I've been considering a tire-mounted rack. I've never liked the cheap ones I owned in the past, letting my bikes clang together. Now I have people telling me that using a rack that holds the bike by the frame will F-up my suspension forks.
So, TL/DR: My bikes ride at an angle on my roof racks, a hitch rack won't work on my truck, and I'm concerned that a spare tire rack will screw up my bikes. What is the lesser of two evils here?
Premium Member
The angle that your bikes fit onto the roof rack should not create any problems, however, you need to make sure they are secure.
If I had a similar problem and was concerned, I'd make a wedge type shim to fit beneath your fork mount/ tray so that you bikes sit more upright.
I've never seen it done, but I almost pulled the trigger on this for a Wrangler, but we ended up selling the Jeep.
StowAway2 swing out frame:
And bolt on a pair of 1upusa roof mounts:
Discussion Starter · #5 ·
That looks pretty slick. . .kinda looks like you'd need an entire car length behind you just to open the rear gate, though!
1 - 5 of 5 Posts
