Jm. said:
I had my romic custom valved
It blew too
For the long term romic owners (that have not had a failure) this is the question you must ask; is your compression adjuster just as effective as it was on day one?
If so, congradulations, enjoy your shock.
Another data point...
My shock is 1 year old..and I hesitate to state that it has never blown. (I hesitate b/c right after I said I never bent a der hanger, or broke a cogset I did both
Anyway my Romic Story: After about 4-5mo's I noticed purely by chance that the compression knob had become innefective. I sent it back to Romic for a off-season rebuild and had it
revalved while it was there. (BBT=Big Boy Treatment) so far I have about 4mos of real ride time on it (season started late Apr) and I just happened to futz with the compression settings today. It worked wonderfully. 4 clicks stiff platform some small bump compliance. 2 clicks very active without a lot of mushyness or wallow.
I don't know how long it'll hold up, but I believe the Romic's blow-out potential has nothing to do with the valving. I believe it's the valve body and seals that blow and I really don't think, adjustments, settings, orientation or valving has any effect on longevity. Either the shock is gonna blow or it isn't
What I don't know is if it is a repairable/replaceable problem or they simply have to chuck out the whole damper. It seems like the folks who have blown shocks continue to blow them after they're "fixed" and the ones that haven't blown carry on... The way I ride I'm sure I would have killed the shock if it was going to happen b/c of useage or settings....and now that I said this I'm going to expect a pool of oil under my bike any day now
The good news is Romic has great CS...the bad news is the chances of needing that CS seems pretty high.
Cheers Gears and Beers!
