1 - 5 of 5 Posts
I am thinking about running a Rohloff Speedhub on my new 29er frame when it comes.
All started when I opted for Rohloff sliding dropouts a little while back.
I want to set the bike up for ocasional singlespeed use and have a very nice chainset I want to use.
If I want to run with a 36t front chainring what size sprocket should (or can) I use when on a 29er with 2.1" tyres.
Thanks,
P::..
Discussion Starter · #2 ·
Now I have had a think about this a bit more. Let me know if I am on the right lines.
Most 26" MTB wil run 42/16 with a Rohloff Speedhub.
This gives a ratio of 2.625
Dia of a wheel 26*Pi = 81.68
81.68 * 2.625 = 214.4
Dia of 29" wheel (Aprox I Know) = 29*Pi = 91.11
214.4/91.11 leaves a gear ratio of 2.35:1
So will 36:15 (2.4) be a reasonable gear?
P::..
Cassoulet forever !
in a first approach, yes.
You can also do the dirty 10% tip :
42|16 - 10% -> 38|16
(close to your result)
For more precision, I think you need a better value for the real diameter of the whells.
Best way would be to calculate with the lowest gear your want.
Derailleurless
Have you checked out Sheldon Brown's online gear-inch calculator?
https://sheldonbrown.com/gears/internal.html
36x15 Speedhub gearing will get you a gearing equivalent to a 22x33 granny combo, and a half tooth lower than a 44x12 high gear. Therein lies the Speedhub gearing conumdrum: do you take an even lower gear at the expense of spinning out at the top end, or vice-versa?
Here are some Gear Inch numbers to compare (and remember that Gear Inches take wheel diameter into account):
Speedhub & 29"er [36x15]
102.6 (high) | 19.5 (low)
Speedhub & 26" [36x15]
91.3 (high) | 17.4 (low)
Derailleur & 26" (44/32/22 x 11/34)
103.8 (high) | 16.8 (low) | 17.8 (22x32)
Other Speedhub / 29"er options:
[36x16]
96.2 (high) | 18.3 (low) < equivalent to a 22x31T granny on a 26" derailleur bike
[36x17]
90.5 (high) | 17.2 (low) < equivalent to a 22x33T granny on a 26" derailleur bike
[34x17]
85.5 (high) | 16.3 (low) < equivalent to a 22x34T granny on a 26" derailleur bike
Discussion Starter · #5 ·
Cheers,
As I am going back to gears more for the high gears than the low I think 36:15 sounds right for me. Although the low gears will be nice again too! Before I went singlespeed my bikes were all set up 2x9 (without a granny ring)
Not like I am going to be stuck with it if it doesn't work out!
The only thing holding me back is the price and the weight. £750 for the OEM1 Disk in black is a lot when I can get a full XTR groupset with disks for less.
P
1 - 5 of 5 Posts
