wow - ok lots of questions to answer!
Re: the Roco:
I've been riding my V-tach equipped with the Roco up hill a lot lately, but mainly for fire road climbs like we have on the North Shore. Mt Fromme in particular (for those of you who know the area) is a fairly continuous fire road climb and the Roco didn't really make the climb any harder than normal.
My fully built V-tach weighs about 47 pounds: it has a full complement of DH components including an 888, Raceface Diabolus everything, fat DH tires, Profile Racing pedals, Gustavs, DT Swiss 440 hubs and 6.1 rims etc...
To be honest, the Roco is NOT nearly as bad as I expected it to be for climbing - at least on the fire roads. Yes, our bikes have a very neutral pedaling suspension: if you're seated and spinning nicely, the shock will barely move. The difference is that the 5th Element or the DHX WON'T move when you're pedaling like that. However, this shock is far superior to a Vanilla RC in terms of NOT wallowing in it's travel. If you're standing up and mashing on the pedals, then you're going to notice a difference in that the Roco is definitely going to move. So will platform shocks, but obviously not as much.
I've done some technical climbing on the Roco. Yes, it does move. Platform shocks will move somewhat in these situations, but not nearly as much as the Roco. Does it inhibit your climbing ability? No, absolutely not. However, you are going to use more energy in this situation obviously. How much more? That I can't say because I haven't done enough of this yet
But, I guess to put it in perspective, people climbed all sorts of stuff 3 years ago before platform shocks were on the on the market, so it's really not a huge concern. Other factors such as frame geometry, suspension design, pedaling efficiency, pedal feedback etc... are probably much more important.
If you pedal while riding skinnies and such it will also move. The platform shocks are solid in these situations which I have to admit is nice. However, you will adjust to the Roco's feel very quickly if you're used to riding a platform shock.
One thing anyone reading this must remember is that our bikes have quite a neutral pedaling suspension to begin with and minimal chain length growth. With the 5th shock, we basically have the compression damping totally minimized. We run both the beginning and end of stroke compression dampers pretty much wide open. We run minimum recommended air pressure and we have the volume adjuster typically turned in only one or two revolutions (out of a possible six). Hence, differences between the Roco and platform shocks may not be as apparent on our frames as they will be on other frames.
I find that you do need a slightly different riding style with the Roco: this is a performance shock and it is happier being pushed. This might sound a bit weird, but frankly, the V-tach frame is very much the same. It's not a bike to just coast through the trails on - it requires the rider to actively push it and it
will perform. Much of this is due to the V-tach's fairly low BB height which adds huge stability but at the expense of ground clearance (i.e. the rider has to be astutely aware of the terrain). Yesterday, we were riding on a trail (Upper and Lower Crippler on Fromme, again for those in the know) a moderately difficult North Shore trail. It's very natural, with lots of tight, choppy sections and a couple of reasonably steep chutes. For the first bit, my riding was really
off. I couldn't link anything together. My bike was bouncing all over the place. Then, I got my mental game back together and just charged the rest of the trail. The bike worked awesomely as did the Roco. It is so active and bottomless that I could pretty much just blast off what ever I wanted to. In the steeps it took me a bit to get used to the much more active rear end. However, let the bike roll and the shock is really, really smooth.
With respect to the Delirium T, I designed this frame to be a heavier duty all mountain frame. My personal opinion is that there are a lot of newer all mountain frames coming out with 6-7" of rear travel, but not the "chassis" to back up this amount of travel. The Delirium T was designed to have a moderate amount of travel (160mm) and have geometry that is very favourable to climbing. However, the frame is definitely burley enough to take on fairly technical trails as well as make a lighter duty free ride frame. Frankly, the V-tach is overkill for many riders. The V-tach is super plush and solid and there is a market for this kind of bike. But for many riders, they simply won't have the terrain or the opportunity to need a V-tach frame (or they can't afford to have two or three bikes including a dedicated FR frame). The Delirium T is designed to fill the need of someone who wants to still ride quite technical trails (and not worry about their frame's durability or performance) but still have a bike that they can ride much more moderate terrain on also.
That being said, there are some tricks up the Delirium T's sleeves (some of which we'll publicly mention and others that we'll let the public find out on their own
It has adjustments for both head angle and chainstay length, which means that this durable all mountain frame can quickly be transformed into a light duty free ride bike. It can change it's head angle from 68 degrees to both 67.5 and 67.0 degrees with just loosening two bolts - about a 2 minute procedure. That means that the frame can be sufficiently slack for dedicated FR style riding. It also means that the frame could be used as a light duty DH frame or even for slope style riding.
This is where a shock like the Roco could be fun. If someone is a smooth rider and wants a play bike that weighs substantially less than a fully built up DH frame, the Roco equipped Delirium T could fill that niche. That is a very SMALL niche, so like I said, we don't expect to sell too many of them with the Delirium T - much more with the V-tach frame. The default shock for the Delirium T will be an air shock - either the Fox DHX air or the Progressive Gravity air. There will be optional coil shocks as well, including the aforementioned Roco as well as either the DHX or 5th coil shocks.
Warp2003: Thanks for the compliments! We do have plans for a trail bike, probably around the mid 5" travel range. It's still in conceptual design right now and will be released early in 2007. This frame is going to be substantially lighter duty than any of the frames that we currently manufacture - pure trail bike and not really designed for any kind of free riding at all. It will probably lose a lot of the features that our other bikes have including adjustable head angle and chain stay length - those features add a significant amount of weight to those frames. Our trail bike will be a much more weight conscious frame. However, being a Knolly frame, there are some other features that it will keep: high lateral rigidity has been a hallmark of our other two full suspension frames and we want to keep that the case here too. As well, full length seat tubes and extra small frame sizes are important as well. We still build highly durable bikes for their intended application and that is something that I don't ever see changing.
Cheers!
Noel Buckley
