Should be the same as on my Blizzard...I have run 2.5 Hookworms on it before with no problem (they are a big 2.5). For off road, I've never used larger than a 2.35 but it could handle a good bit more. Hope that helps a little.bikin said:What's the widest tires I can mount on the back of this frame?
Use the specs on my Tire Site to compare your current tire with other tires you are interested in using.bikin said:What's the widest tires I can mount on the back of this frame?
The Blizzard is aluminum right? AFAIK the Hammer is steel, if so they are different frames, so they *might* not be the same as far as tire clearance (even if the geometry is the same). Might be a good question for Rocky tech support...namaSSte said:Should be the same as on my Blizzard...I have run 2.5 Hookworms on it before with no problem (they are a big 2.5). For off road, I've never used larger than a 2.35 but it could handle a good bit more. Hope that helps a little.
Blizzards are steel. Always have been.fsrxc said:The Blizzard is aluminum right? AFAIK the Hammer is steel, if so they are different frames, so they *might* not be the same as far as tire clearance (even if the geometry is the same). Might be a good question for Rocky tech support...
