I looked at the parts diagram and it looked like a drop in replacement. I purchased the RockShox XC32 Spring Internals Left 26/29 120 Solo Air replacement part, but have encountered an issue with the install.
When I install the Solo Air it doesn't fully seat so I can't engage the threads on the top cap. The top cap looks to be about .5-1" above where it needs to be. Looking at the bottom of the upper tube there looks to be a part that the spring rests on. However I'm not seeing this part on the diagram or rebuild instructions. Any advice on how to remove it? It looks like I need to pull the lowers. I'm hoping it is not a permanent part on the upper tube that can't be removed.
