Hi all
Currently in the middle of a teardown and rebuild of my Super Deluxe RCT, and have also disassembled the compression assembly from the piggyback.
Now the curiosity having gotten the better of me and trying to learn more about shim tuning, I've toyed with the idea of changing around this stack. While I don't claim to know of a sure fire way to make noticeable differences, would love to hear peoples ideas or suggestions around possible improvements/tuning capabilities.
The shock is on my 2019 Remedy 9.9 and overall I feel the standard piston tune is nice, but give it more than a click or two on the LSC adjuster (which I'm assuming is influenced by this assembly) it leads the the bike feeling wooden. Would changing the shim arrangement give me a more useable range of adjuster from the shock?
Vorsprungs overview of this vs Monarch gives a good overview of how the lockout works, with the lever pushing a small poppet into the centre of the silver bolt restricting oil flow and giving a lock out effect. Turning the LSC dial screws in a ported adjuster into the silver piston/bolt which from what i can tell would limit oil flow to the shim stack? Top left to right shows what's on the left side of piston/bolt in the centre, while bottom left to right shows what's on right side.
Any ideas/comments of what could be done here would be appreciated! Even as a learning experience or resource for others, keen to learn more about how the assembly functions and its capabilities :thumbsup:
(NOTE: will get shim measurements shortly, as my callipers are not working currently. But they appear to be identical to what's found on the main piston assemblies)
