Hi,
I have just purchased a Nukeproof 275 pro with a Rockshox super deluxe shock.
I set sag/ rebound etc and went for a couple of rides and all felt well. I decided to fit a bottomless token to see how this felt and did a little research and fitted this no issues at all.
After riding a trail I decided to take the token back out as I wanted a fresh comparison.
After taking the token Out I re-pressurized the shock and re-set sag. After a mile or so I decided on a whim just to check the pressure again and it seemed to have lost about 20 psi. I pumped it up again and stopped again in about another mile - and again it had lost pressure.
When I got home I depressurized and opened up again just to check and everything looks A-OK. So I pumped back up to 170 psi and within a couple of hours it was down to 100 psi. The weird thing is that when I keep the pump attached it doesn't lose pressure - Not at all. As soon as I release pump the pressure starts to drop.
Someone had a theory about having to charge the negative air chamber but this wouldn't cause the shock to lose air surely?
The shock is brand new on a brand new bike and obviously I'll send back under warranty but if there is a simple fix that would negate me having to send it back to supplier I'd prefer to do that.
Any ideas or thoughts?
Thanks in advance
Neil
Thanks in advance
Neil
