1 - 1 of 1 Posts
I picked this up at my lbs for cheap, to put some new life into an old bike.
I went to install it, and realized that the second it compresses, the shrader valve is going to get severed off. It holds air fine, I asked the LBS to put it to 200 just so I can measure things. I don't have a shock pump. (Installing it is going to need some custom machined brackets)
I googled the shock, and I found about 2 pictures. Both, to my surprise, had the valves ligned up.
I searched the shock for anything that may allow me to twist it back in line, but found nothing. I deflated it all the way, and tried to just use brute force, but still nothing. There is a seam that runs around the top.
A picture is attached.
Is this normal? If not, how should I fix it?
1 - 1 of 1 Posts
