1 - 10 of 10 Posts
My 2012 SID XX no longer locks out completely, as it used to. There is some play, about 1/2", when locked out. I bled the remote w/ no improvement. I'm assuming a rebuild is required and wanted to know if this problem will be fixed w/ a standard rebuild of the fork using the 32mm SID Service kit. TIA.
You don't ask those questions. Oil degrades in your fork just like in your car. Well, not JUST like it, but you get it. Just get the level back up to spec and let it work for you.
It's just maintenance, man. Happens out of the box sometimes on brand new forks. I rebuild a lot of brand new forks for people. I don't like it, but you just have to sometimes.
mk
Discussion Starter · #6 ·
trailbildr - Can the damper fluid be changed or topped off without removing the lowers? Can I simply remove the remote/top of the right leg and drain the current fluid and replace w/ the correct amount of new fluid? TIA.
Class Clown
Might as well change the oil in lowers as well, give the fork a nice service and it will love you back. You can buy maxima fork oil pretty cheap.
Also i believe it should be normal for the fork to move slightly in lockout.
Yeah, you can remove the damper and replace the oil with the correct volume. That's the oh-fee-shul right way to do it. If your fork moves slightly in lockout, add 3-5cc more damper fluid. RockShox will tell you that it 'may' move a bit, and some dampers do, but you can usually get rid of that 1-3mm of travel before lockout with a few cc of oil.
That's like Fox telling you that getting 115mm of travel out of a 120mm travel fork is 'within tolerance'.
mk
My '08 Reba has always had about 1cm of play when locked out (which IS normal). I thought most Rockshox did. Are you sure the SID didn't? I think most ppl report lockout NOT working at all when oil level is low. Not just having a bit of squish.
Either way, if you have >50 hrs on that fork, might as well do a full service. Most RS forks are pretty easy to maintain after the first time.
I mostly see lockouts that work too deep in the stroke as an indicator of low oil level in the damper side. When the damper hits the oil during compression and the lockout is on, it hits a wall. I notice it when installing dampers into forks with correct oil volumes with the lockout on. You have to push past the lockout to engage the threads or just turn the lockout off.
So, again, while many people (and RockShox) say that the play is 'normal', they also say that their fluid levels are +/- 3-5cc, so you have some room to alter the feel of the lockout. Sometimes it works. Actually, most times it works.
mk
1 - 10 of 10 Posts
