Hello
I have some Rockshox Revelation RTL forks in which I got a remote kit for it. Unfortunately, the damper didn't have the floodgate adjuster, a feature that I liked, but other than that i worked fine. I managed to find a Damper remote with a floodgate but when I fitted it its default position was closed so the suspension is always locked unless I press the lever, the opposite to how it was before.
Question is, can I do anything to reverse ist default position within the damper?
Thanks,
Dan
