I use my pike (426 coil u-turn) for riding park and lately i have been noticing a loss in compression, the forks compression adjustment was weird to begin with. The blue knob on top was more like an on off switch, it didn't do anything when placed in between the extremes, so i just ran it in the "locked" position (which wasnt even locked) and adjusted the compression with the floodgate. The fork only became locked out when I turned the floodgate all the way up, and it was soft when it was all the way down, so i ran it in the middle. Now after about 6 months of riding it, it has slowly lost compression and now its at the point where it is in the locked position and the floodgate is turned all the way up but u can still go through the travel. I also noticed a little bit of oil coming out from around the little rubber o-ring around the floodgate knob. What could be the problem?
