I had recently serviced my Rockshox Monarch RT3 shock - just inspection/clean/oil/grease. However, after installing I noticed it was stuck down halfway. Figured some air got in the negative chamber so removed the air from the valve and then went to remove the aircan. There was a super loud pop when removing this - I hope this hasn't damaged the shock...
I reassembled and pumped up to 200psi in increments. The shock holds air but fully compresses and bottoms out regardless of pressure. The lockout actually works and restricts movement but when it's open it fully compresses.
I disassembled the shock again and found that one of the seals under the aircan had a very small chip in it - would this be enough to cause the above issue?
