hey, my name is Duncan too. first or last name? It was my mom's maiden name, my middle name. sorry for the OT, just don't see too many Duncans around.
Check out the threads on the air can mods for the DHXair/RP3 shocks. The outer sleeve of yoru Monarch is held in place by a c-clip. If you deflate the shock and remove the c-clip, you can remove the outer sleeve. Fill it with something like grease of plastic and put it back on. You can custom tune the volume to your preference to achieve the progression you want.Duncan1104 said:I was just wondering where I could find a regular air can for my monarch. It came with the high volume air can, which provides too linear of a stroke for my bike. The shock's size is 200x51mm if that makes a difference.
Thanks MK, I'll look into it.MK_ said:Check out the threads on the air can mods for the DHXair/RP3 shocks. The outer sleeve of yoru Monarch is held in place by a c-clip. If you deflate the shock and remove the c-clip, you can remove the outer sleeve. Fill it with something like grease of plastic and put it back on. You can custom tune the volume to your preference to achieve the progression you want.
_MK
