1 - 7 of 7 Posts
Took me ages to track down what I needed to convert my Reba to Debonair, so I thought I would share with you in case anyone else wants to do this.
Initially I was looking for a debonair air shaft but it's just the seal head that is needed. I knew it could be done as the new SID is debonair.
See pictures for part number and instructions
Will post again after the conversion
Sent from my SM-G930F using Tapatalk
Do you feel any difference after upgrading to debon air?
Beside debonair seal head do I need Jounce bottom out bumper?
New rebas and sid has this bumper with plastic cup in lower leg.
Thanks :thumbsup:
The Debonair seal head on 32mm forks does not increase the negative chamber volume like it does on the larger legged forks, so there is little change in performance. It is a simpler system though.
Could the seal head be mounted upside-down? If the o-ring is at the bottom, the air volume above it would be larger.
1 - 7 of 7 Posts
