1 - 20 of 26 Posts
My wife's bike has a Rockshox Sektor on it and it has one of the expanding collet axle like this one
Line Steel Tool Office instrument Aluminium
Me and Her both hate this axle as the corners of the area you use to loosen or tighten it have gotten bent up and sharp, as we have to take the front wheel off every time we go ride as we use fork up roof rack trays.
So now on to the question can we replace it with the new style one like this one:
Line Metal Steel Aluminium Tool
******UPDATE****** The axle Part Number from when this was originally talked about, and figured out has changed to 00.4318.005.006 the link for the part on BTI's Website is BTI | Rock Shox Maxle-Ultimate Road Q/R 15x100mm T-A kit******UPDATE******
Discussion Starter · #6 ·
So I managed to stumble across someone out on the trail that had a pike so I asked if i could try his axle in my wife's fork and he said sure and let me try and everything seemed to fit so we ordered one from the local bike shop.
I picked it up and installed it today and everything fits fine and here is a picture.
Spoke Bicycle wheel rim Rim Bicycle accessory Bicycle part
Resurrecting and old thread since I've just run into a problem trying to upgrade to the new lever. I was sent a 00.4318.005.001 Maxle Ultimate which appears too long to replace my 15x100 Maxle Lite. Did I get sent the wrong part or do I need a different part number?
Discussion Starter · #15 ·
I contacted the seller and they reiterated that 00.4318.005.001 is for Pike/RS1 only. It's possible that RockShox changed part numbers and they certainly changed the name from Maxle Lite to Maxle Ultimate. The Maxle Lite XC, which is what I originally have, seems to have a newer version called Maxle Lite 15mm.
I'll check the dimensions of my Maxle against the 00.4318.005.006 part that you posted. The first difference that stands out to me is the threaded section of 12mm on the road Maxle versus 9mm on the off-road applications.
Okay, I just received 00.4318.005.006 which looks like the correct replacement with the new style lever. So, maybe Rockshox changed their part numbers or whatever, but 00.4318.005.001 is NOT the replacement for the old 00.4318.005.002 Maxle Lite. Order 00.4318.005.006 also described as "Maxle-Ultimate Road 15x100mm."
Product Metal Office supplies Cylinder Steel
Discussion Starter · #19 ·
Awsome, enjoy the new axle, I will put an update in the original post so that no one else makes the same mistake. Shame they made it so complicated.
1 - 20 of 26 Posts
