1 - 20 of 28 Posts
Alright - reached out to Turner and they don't seem to have these anymore. I have a 07 Flux and need to get the rockers for them.
I've got a beat on some rockers from a spot and pack, but my question is do all rockers from 06,07,08 turners basically work across their model lines that share a similar suspension setup?
There's a few threads here that talk about compatibility with spots and packs as it relates to the rockers, but nothing specific to the flux.
Thoughts?:thumbsup:
carpe mañana
Yeah, you can put Flux rockers on one of the other two but not the other way around. It may be a pita to get Flux rockers unless Turner gets one on trade in with a mangled front triangle. Leave a note with Turner to keep you in mind when that happens.
In the interim your best bet would be to find a local welder to fix them up or a local machine shop to replicate them ($$$). After welding they'll need to be heat treated.
_MK
There's a thread on this somewhere, but wasn't one iteration of the Spot rockers -very- close to matching the Flux rockers? No idea if that's factual or if they're maybe close-but-not-compatible? But if you end up needing a set of 5.3 Spot rockers, I have a set on the shelf. --Matt
Discussion Starter · #8 ·
MW - I will PM you about the 5.3 spot rockers.
I've also heard the sultan rockers should work on my Flux.... but apparently none of these rockers are available at turner, so I'm on a wait list with them.
I'm 90% sure I still have a set of 07 Flux rockers. The left one has a hairline crack starting at the shock valve relief cutout. The right one is perfect.
So ... if you only need the right one, I've got you covered.
Bite Me.
The 5.1 rockers should work on the Flux. I swapped them out on my Sultan with no issues, and the TNT Sultan used the same rockers as the Flux. I still have the 5.1s if you're interested -
Since this thread is still going, I wanted to add part of an email conversation with aa240sx . . .
mwnovak said:
I -believe- the TNT Flux used a 6.5x1.5" shock to get 4" of travel, which means the stock Flux rockers gave a leverage ratio of 2.67:1. The TNT Spot used a 7.5x2" shock to get 5.3" of travel, meaning the 5.3 rockers have a leverage ratio of 2.65:1 . . . which is pretty darn close to your stock rockers (you'd lose all of 0.025" travel with the 5.3 rockers).
Where this gets messy is how the rockers may differ in their dimensions: differences in the overall length and (particularly) height of the rockers may make the swap either undesirable (in terms of subjective suspension quality, bottom bracket height, etc.) or simply untenable (in terms of tire/frame clearances). For instance, two old posts in MTBR (http://forums.mtbr.com/1451895-post22.html and http://forums.mtbr.com/1407576-post9.html) suggest nearly 1.25" difference in length between the Flux and 5.3 Spot rockers . . . which I find a little hard to believe, given how close the leverage ratios appear, but you can see how this starts to get a bit wonky.
The 5.1 rockers from a Spot should have a leverage ratio of 2.55:1, suggesting that the 5.3 rockers might be the closer match to stock Flux rockers? (though we're ultimately talking about less than 1/8" difference in total travel)
This is mostly idle curiosity on my part, but I can't imagine this is the last time a TNT Flux or Sultan owner will find themselves in need of replacement rockers. Might be worth documenting how/if the 5.1 and 5.3 Spot rockers impact the Flux (travel, BB height, geometry, subjective quality of suspension travel, etc. etc. etc.).
Or maybe this info is "out there" already?
--Matt
Bite Me.
The math gets real weird if you delve too deep. I can only say that the 5.1 rockers on the Sultan didn't really alter the ride that much and didn't create any problems with too much or too little travel - both the Flux and Sultan use a 6.5 x 1.5 inch stroke shock and each has 100mm of travel, so the swap worked just fine. If anything, I noticed a slight bit more plushness in the early part of the stroke, but it could have been the kool-aid too. When I ran the 5.5 rockers on the Sultan, there was more of an effect, but I also had issues with rear tire contact on the seat tube when running big tires. Bottom line is that the 5.1s are known to work fine if the standard Flux rockers can't be found. This thread is like old home week for non-DW Homers.
  • Like
Reactions: tedroy
I find it hard to believe that a bike only 4 yrs old and the manufacturer has no replacement parts for them. But I don't blame Turner since they're a small co. and can't really afford to stock replacement parts for models they discontinued.
Fair enough. Did you happen to grab comparative BB height and HA measurements with the 5.1 rockers? Again, merely curiosity on my part.
If you think this is bad, I have a "2007/08 RFX FrankenTurner Documentary" thread in the works that should have folks rolling their eyes petty good. Though come to think of it, I guess the 2007/08 bikes are the most current production RFXs available. :eek::p:thumbsup:
Sorry, I couldn't resist.
--Matt
Bite Me.
Nothing scientific - sorry.:confused: As near as I could tell there was no noticeable difference in either BB or HA. In theory the BB would raise a bit and the front end steepen, but the 5.1s are only slightly longer out the back and also off the front. I was trying to get a little more initial stroke compliance out of the RP23, which the rockers seemed to do - but the diff was not day and night by any means. I put the stock rockers back on for a few endurance races and the rear end felt a little tighter, so I just left them on.
TNT Flux and Sultan rockers are the same
2007 were the thinner "old" Flux design, like on the HL rear ends.
2008 were the thicker design, much stronger, will fit earlier Flux frames, etc.
The 2007 and earlier rockers were prone to cracking at the air valve relief.
Turner Flux Rockers, Shock and HL Available
Reviving an old thread because my 2007 Flux is dead. It broke on the seat tube just above the shock mount, like many others before the switch to the down tube mount. It'd be nice to see the parts live on. I have a set of post-2008 Flux rockers (fits '05-'08), an original HL suspension (also fits old Burner V3 '02-'04, and Sultan V1 '07-'08), and a Pushed Monarch RT3(no scratches on shaft) for it. Open to offers and hard luck stories.
I have a TNT Flux that will be traded in when I get my new Flux. Anyone out there looking for parts had better make sure that you are first on the list. It is a prototype Flux front triangle (supposed lighter tubes) and a Nitrous rear. I've never weighed just the frame, but it is light.
1 - 20 of 28 Posts
