Rock Shox SD Coil travel/stroke adjustment?
1882 Views 9 Replies 5 Participants Last post by  Stickey1048
Hello all,
I know that you can travel the air version of the Super Deluxe to any stroke you prefer by the internal spacer.
What I am wondering is, does the same apply to the coil Super Deluxe?
I couldn´t find a used 230 x 65 in the past weeks that would fit my Slayer, so I am exploring other options.
Thanks for helping!
  • Like
Reactions: 1
1 - 10 of 10 Posts
Hello all,
Thanks for helping!
You should be easily able to find a 5mm spacer for it, or ask your LBS.
Hello stripes,
maybe I wasn´t clear. I would go and buy a shorter stroke shock and get rid of the travel spacer, as long as the technology is the same as the air Super Deluxe. Because in that one, you can remove a spacer to bump the stroke from 57,5 mm up to max. 65 mm.
I need to know if the coil SD works that way.
yes, you can do that
Do you happen to have any pictures or know of a source which might have any?
Hello stripes,
You could but is it because you want to change shocks from air to coil, or you already have a coil?
I have a Super Deluxe ultimate air shock, but I would like to try a coil, after I was fairly unimpressed by the Fox DHX2, which came with the frame.
  • Like
Reactions: 1
the spacer is the plastic disc underneath the bottom out bumper
  • Like
Reactions: 1
Thank you!
Do you know if the sidluxe works the same way? Meaning - for shocks of the same length, they stroke changes are just internal spacers up to the maximum stroke for that length?
1 - 10 of 10 Posts
