1 - 6 of 6 Posts
Dear all
I own Anthem 29 with RT3 MM (165x38mm).
Damper has one season (around 1000km)
After winter brake I started to ride however firs kilometers showed some problems.
When I put it on platform mode there is some initial click, even when I push the saddle firmly to check the click appears.
At first I thought the sound may come from loose cable housing but this was wrong idea.
After changing mode to “Open” or “Locked” damper stays quiet and works fine.
Have You got any ideas what can I check, or how to eliminate this noise?
Discussion Starter · #6 ·
This thread can be closed.
Unfortunetely none of w local services dound any issue.
They rebuilded shock twice with no result. Ensured that it works properly despite noises and i can ride safe.
1 - 6 of 6 Posts
