1 - 1 of 1 Posts
Hey Guys, I just installed and set up my Revelation 426 Air U Turn. It has adjustable travel from 100mm to 130mm. When the fork is set right at its minimum 100mm or maximum 130mm travel it works fine. When its set anywhere in between I can hear a slight "clicking" sound from inside the fork. It clicks right as pressure is put on the fork. Other than that it works fine. The click is just kind of annoying. Does anyone have any answers as to why this is happening?? Thanks
P.S - I did set up the positive and negative air pressure correctly.
1 - 1 of 1 Posts
