1 - 12 of 12 Posts
Theres not much to using a dual air fork. I had never even seen one much less used one and it took me about 3 minutes to figure it out. Basically if you want the simplest setup, just put the same pressure in both chambers. Thats it.
I dont think the Revelation with a coil spring would be popular. I think people like it because it is a light 150mm fork that you can get in any axle configuration. If you want a coil fork, you want the lyrik.
There really isn't that much of a weight difference between the coil and the dual air. On the older pikes there was only .4 of a pound difference between a coil u-turn and a dual air model. That little bit of weight is worth it to me not to deal with air.
"El Whatever"
Not really... I want a Sektor with a BB damper or call it a Revelation with a coil spring but not a Lyrik.
I can only compare the Dual Position air to a Air U-Turn and both have pros and cons.
Dual Pos Air
Pros
- Quick travel change
- Light and simple, set and forget
- Feels nice for an air fork.
Cons
- No chance to set it up to anywhere in between to dial in geometry
Air U-Turn
Pros
- Can be set up to any travel setting within the range
- Dual Air set-up makes it really flexible, plush, stiff, you name it.
Cons
- Slightly heavier
- Always could develop some knocking issues
- Selecting travel is not really on the fly. You can do it while riding, but takes a lot of turns to go from full to short travel.
I would like some more plushness out of my Dual Position Air, but I have little ride time on it and it could be that I still need more break in or work on the set-up.
The BB damper is better than the standard Motion Control.
dkbikes4life said:
The biggest question would be, do you need a dual position fork? I have the dual air, and really like it, when it works right. Having some issues with the compression/lock out knob.
What is the issue you're having? could you elaborate? I'm having some myself and I read mixed things but I know I should get more low speed compression and not only a lock out at last "click":madman:
1 - 12 of 12 Posts
