which fork would you go for? I can get them about the same price...specs...
RS Recon 351 coil U turn FRK 08
* Adjustable travel from 85-130mm via U-TURN spring
* External rebound adjustment
* No PopLoc remote
* Motion Control damping
* claimed 4.5 lbs
* 185mm steel steer tube
* Accepts 51mm IS Disc brake (rim brakes cannot be used)
OR.....
Marzocchi 55 R (08)
# 140mm Travel
# Rebound
# Air PL
# One side Coil
# Alloy Steer Tube
# 35mm Aluminum Stanchions
# 6” Post Mount (Max Disc 8”)
# New 20mm QR Axle
# Weight(claimed): 6.04 lbs.
# 3 Year Manufacture Warranty
What do you say?
* No PopLoc remote
* claimed 4.5 lbs
OR.....
Marzocchi 55 R (08)
# 140mm Travel
# Rebound
# Air PL
# One side Coil
# Alloy Steer Tube
# New 20mm QR Axle
What do you say?
