1 - 4 of 4 Posts
Hey MTBR!
Right now I'm in the process of building up a new bike, I just landed an awesome deal on a cannondale prophet frame and am itching to start building it up.
As far as suspension goes I want to go with the Rock Shox Pike ( It seems like a good fit for the bike and you can score great deals online too).
My main dilemma is knowing which one the choose! I seem to find a different freaking model with every search!
I asking everyone here what the different models for the Pike. If someone knows alot about the Pike series then your knowledge is very useful to me.
ehadzima said:
Hey MTBR!
There are many different models aftermarket and oem. Most common would be U-Turn Coil or Dual Air / Dual Air U-Turn. Then there are different syles of the MoCo damper - tooled, remote, standard. Steel or aluminum steer tubes, hollow & solid crowns. Figure out if you want air or coil first.
There's loads of information in this forum. One thing to look for is info on adding/changing compression dampers, and changing coil to air. So, for example, if you find a good deal on a 327 which doesn't include a motion control damper, you can figure in the additional cost of adding moco yourself. In other words, you might get a better deal upgrading a lower level fork.
1 - 4 of 4 Posts
