1 - 5 of 5 Posts
Haro Sonix LT VL120
So my mc 3.3 shock doesnt fully lock out. With the floodgate dial all the way to closed and the lever on floodgate position it feels firmer but not locked out like it usually does. When the lever moved to the lock out position it feels just like having it in the floodgate position. Firm but not locked out for sure. Usually locked out it has a little bit of travel for bump absorption but thats it. Now its firm but I can compress the shock quite a bit. I know these cant be disassembled like the monarch other than the canister being removed. Is there a way to check the amount of nitrogen in the shock?
Haro Sonix LT VL120
Discussion Starter · #3 ·
nope not at all I love this shock and works great otherwise but its nice to know the lockout works and I prefer a slightly firmer platform than what Im getting for smooth trails
At the bottom of the shaft there should be a little port, I'm pretty sure that is where the nitrogen( rock shox says you can use regular air) goes. But the only setback is you have to get an adapter to screw in there
1 - 5 of 5 Posts
