Ummmm that won't work. Rockshox front discs are about 163mm diameter. An standard 160mm rotor won't get full pad contact in the caliper. The Amp front is smaller, and neither the Amp or Rockshox front pattern is the same. The rear BCD is identical for both, and its also the same as Hayes ISO 6-bolt pattern (so Amp/Rockshox rear rotors fit ISO 6-bolt hubs just fine). However again, neither disc diameter is the same as anything standard for other brands. The Amp rear rotor is smaller than the rockshox and both are less than a 160 but more than a 140 as I recall.
