1 - 9 of 9 Posts
Hey all. I'm building a Haro extreme x3 dual suspension and need forks. I am currently being offered some RS Tora 318 solo air shocks for 200 usd. Is this a good deal? I weigh about 150-155 and do take jumps but nothing huge, and little to no drops. Would these forks work well? Thanks all
I have that shock on my Specialized RH Comp. I see they go for around $260 on the market. Fork will work well as you can set your own compression on the air forks.At your weight- put around 110 lbs of air in the shock . (YOU will also need to purchase a shock pump- they go for around $30.).It is probably the cheapest of the air shocks so I would go for it if I were you. I have no complaints with mine. The air does not leak out much at all with mine. I check the pressure once a month and I don't lose anything.
1 - 9 of 9 Posts
