I offer rock protection plates for the:
*** Nomad 3
*** Bronson Carbon
*** Bronson Aluminum
*** 5010 Carbon
*** 5010 Aluminum
*** Tallboy Carbon (TBc)
*** Tallboy Aluminum (TBa)
*** Tallboy 2 Carbon
*** Tallboy LTc (TBLTc)
*** Blur TRc
* Niner
*** Rip9 RDO/Carbon
*** Rip9 Alumimun
*** Jet9 RDO/Carbon
*** Jet9 Aluminum
*** WFO
*** RKT RDO
*** One9 RDO
*** Air9 RDO
* Ibis
*** Ripley
* Yeti
*** SB95 Alumunum
* Turner
*** Czar
* Spot
*** Mayhem
I have many happy customers...here's one. Thanks Phil!
luv2mtb.blogspot.com
Most plates are $40.
I ship promptly using USPS First Class ($6 USA, $8 Interational)
I accept PayPal: payment links by plate model and shipping location (USPS First Class Mail) below:
**** PayPal ordering links below *
Guerrilla Gravity Revved extended coverage ultra-duty (6.5" additional protection plate for the downtube)
Pics: Guerrilla Gravity Revved extended coverage protection 2 piece
Guerrilla Gravity Revved regular coverage ultra-duty
Pics: Guerrilla Gravity Revved protection plate
Note: requires removal of factory rubber guard.
Spot Mayhem ultra-duty
Hightower ultra-duty plate (60g)
The Hightower does not have water bottle mounts on the bottom, so attaches with supplied 3M VHB tape.
Here's a link to pictures of the plate: New photo by Ron Saito
Nomad 3 ultra-duty plate (58g)
The Nomad 3 does not have water bottle mounts on the bottom, so attaches with supplied 3M VHB tape.
Here's a link to pictures of the plate: Sign in - Google Accounts
Bronson Carbon (V2 2016-current) ultra-duty plate (58g)
Here's a link to pictures of the plate: Bronson/5010 CC V2 protection plate
Bronson Carbon (V2 2016-current) top linkage shield (24g) $20 + $5 shipping
Here's a link to pictures of the top linkage shield: Bronson/5010 V2 top linkage shield
Helps keep the linkage clean by deflecting material from the rear tire.
Bronson Carbon (V2 2016-current) ultra-duty plate WITH top linkage shield BUNDLE $55 + shipping
Bronson Carbon (V1 pre-2016) ultra-duty plate (58g)
Bronson Aluminum (V1 pre-2016) ultra-duty plate (58g)
Note: Santacruz does not ship the Bronson Carbon with water bottle bolts, and the water bottle mounting holes must be cut out.
The Bronson Aluminum ships with plastic bolt, which should not be used to fasten the protection plate.
The small Bronson Carbon apparently does not have water bottle mounts on the bottom, so mounting will require zip ties, etc.
5010 Carbon (V2 2016-current) ultra-duty plate (58g)
5010 Carbon (V2 2016-current) top linkage shield (24g) $20 + $5 shipping
5010 Carbon (V2 2016-current) ultra-duty plate WITH top linkage shield BUNDLE $55 + shipping
5010 Carbon (V1 pre-2016) ultra-duty plate (58g)
5010 Aluminum (V1 pre-2016) ultra-duty plate (58g)
Note: The 5010 Carbon V1 does not ship with any bolts, and the water bottle mounting holes must be cut out. The 5010 Aluminum V1 ships with plastic bolt, which should not be used to fasten the protection plate. NOTE: The small Bronson Carbon apparently does not have water bottle mounts on the bottom, so mounting will require zip ties, etc.
Tallboy (LTc) ultra-duty plate (58g)
Tallboy (LTa) ultra-duty plate (60g)
Tallboy (LTa) standard plate (82g)
Note: the Tallboy Aluminum ships with plastic bolt, which should not be used to fasten the protection plate.
Tallboy 2 (Carbon frame) ultra-duty plate (66g)
Pics: https://picasaweb.google.com/108286714765260833631/Tallboy2CarbonProtectPlate
Note: you can confirm you have a TB2 by the lower offset linkage; TB1 lower linkage is not offset.
Tallboy (Carbon frame) ultra-duty plate (66g)
Tallboy (Carbon frame) heavy-duty plate (only original shape available) 93g (only 2 left)
Tallboy (Aluminum frame) standard plate
Tallboy (Aluminum frame) ultra-duty plate
Blur (TRc) ultra-duty plate (60g)
Note: small TRc frames have no lower water bottle mounts; I can supply 3M VHB mounting tape if requested.
2017 Rip9 RDO ultra-duty plate
so longer water bottle bolts (M5 x 0.8) are needed to mount the plate (which are NOT supplied).
You can find these at any bike store or even Home Depot.
2013-2016 Rip9 RDO/Carbon ultra-duty plate (65g)
2017 Rip9 Aluminum ultra-duty plate
2013-2016 Rip9 Aluminum ultra-duty plate (54g)
pre-2013 Rip9 Aluminum ultra-duty plate (61g)
2017 Jet9 RDO ultra-duty plate
USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=WWH64KBK3MJGA
International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=BQ9SAPRA8CC98
Note: This plate mounts over the Di2 compartment. The factory bolts holding this part is too short,
pre-2017 RDO/Carbon Jet9 ultra-duty plate (65g)
USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=4XPDLYZ8VNFA6
International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=EJ4Q6HMPK7RAJ
2017 Jet9 Alumimum ultra-duty plate
USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=BQ9SAPRA8CC98
International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=GNMKFGDK9A97L
pre-2017 Jet9 Aluminum ultra-duty plate
pre-2017 Jet9 Aluminum standard plate (84g) (only 2 left)
RKT9 RDO ultra-duty plate
Pics: https://picasaweb.google.com/108286714765260833631/NinerRKT9RDOPlate
Note: size XS and SM RKT9 RDO frames have no lower water bottle mounts; I can supply 3M VHB mounting tape if requested.
ONE9 RDO ultra-duty plate
Pics: very similar to AIR9 RDO; see below
Note: attaches with supplied 3M VHB tape.
AIR9 RDO ultra-duty plate
Pics: https://picasaweb.google.com/108286714765260833631/NinerAir9RDOPlate
WFO - 2014-current - ultra-duty plate
WFO (pre-2014) ultra-duty plate
Ripley - ultra-duty plate
pics: https://picasaweb.google.com/108286714765260833631/IbisRipleySkidPlate
Note: only confirmed to fit the medium. other sizes may require modifying the plate to fit.
Czar - ultra-duty plate
pics: https://plus.google.com/photos/108286714765260833631/albums/6126611822380335185
Yeti - SB95 Aluminum
pics: https://picasaweb.google.com/108286714765260833631/YetiSB95ALPlate
- Guerrilla Gravity Revved frames
- Santa Cruz
*** Nomad 3
*** Bronson Carbon
*** 5010 Carbon
*** 5010 Aluminum
*** Blur TRc
* Niner
*** Rip9 RDO/Carbon
*** Rip9 Alumimun
*** Jet9 RDO/Carbon
*** Jet9 Aluminum
*** WFO
*** RKT RDO
*** One9 RDO
*** Air9 RDO
* Ibis
*** Ripley
* Yeti
*** SB95 Alumunum
* Turner
*** Czar
* Spot
*** Mayhem
Cytoe Industries - The small company you need to know...
O.K. you spent north of $2K on your Tallboy and now you're ready to shred. The bike is built to ride and ride fast but it's carbon, and the...
- USA -> PayPal
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=456H8DWMLRV7Y
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=QB7HWUHZ7VSBL
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=RQU3B4L726P9N
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=DGFRDP8NSNHG6
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=JN69LVHHQ2232
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=AW4RJ5P488BMN
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=TE8G5H3TQJR6W
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=7FAHLVWWT5QPW
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=CVZFFBN75YL8A
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=MYNBNPK8N9BHC
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=W3F88TYR2VYK2
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=PCSKM6MTDJKAA
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=DY5HED5ZV9Y2U
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=QDP7WHT3NHY9Y
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=6ENSZA77J72ML
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=PLNBCPXD8W5RJ
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=RKLBEBFVGNX5G
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=NSWNNMFDX5F5G
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=D8A6C4NKHC6WY
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=TLTCW5ANLDQ9W
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=8N3ZGWX4AVNFA
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=EHY3JNTB7BNDA
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=9T9ZNGXKBM2LA
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=BD8E2KANKY6PQ
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=SK43ULPNZ27FJ
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=ZN2J94QY2UZ28
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=7A3DJDUW76RU2
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=H4XVTJX4LVW32
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=VAHW59Y9YML2S
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=JC653R688MRZE
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=F85WGTSHJX9NQ
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=DSFU5PDYJCZZ4
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=AAZDLN26C6XA4
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=PQXKBFEXZLV9U
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=FHJUFU2KWRBYA
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=KRK9QG6SVENVY
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=7GTACXV828W6Y
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=BL7AZKF9JWBFW
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=7DMMTKB2CVZWW
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=P7S3U9VCK7EWL
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=CJZS5A4F7WSZE
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=7SE324CJXSCFE
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=8FPECW7BEJYAS
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=B4JUY88S3WYE4
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=ULULGBEURU2C2
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=VZWYGJASYWHZL
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=CPQYQTFDQL79C
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=DA9K5PL86MS6U
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=2T8JJ4YMDDYLJ
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=8G4SLWGFE8654
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=8SV9BE33NBDCG
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=SVJ44TLP83RSG
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=6GWHUYM3W7YNY
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=GHHH7ZAAB7EM6
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=L5BT5PJL4QH6Q
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=FU55PMQQ2X6BW
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=LXUGSRUMC8Y58
- International ->https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=8R8YRJV8YGT32
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=5PVWMNGKYL4TL
- International ->https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=8N87WN58CXK2G
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=CXCGKHPYB5T34
- International -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=2QZ3YB3MW7VGA
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=H2JW7WK9CEQ22
- International - https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=2BWJ9BK6QSNWA
- USA -> https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=4TQF5JDP49ULA
- International - https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=9AA6L7RNUUVTA
