Its a road crankset for a reason, Personally I wouldnt risk screwing my nice shiny new DuraAcesPekkaP said:
Its a road crankset for a reason, Personally I wouldnt risk screwing my nice shiny new DuraAcesPekkaP said:Anyone running road cranks on their mountain ss? Been planning to buy set of 180mm Dura-Ace's. Are those strong enough or do they fall in pieces in first drop off?
Theyre 110 BDC, cheaper then DA and strong as heck.PekkaP said:Anyone running road cranks on their mountain ss? Been planning to buy set of 180mm Dura-Ace's. Are those strong enough or do they fall in pieces in first drop off?
What are you running with your compacts? They usually come 34/50, so are you just using the 34?JMH said:I run road cranks on my SS. FSA carbon ones, compact. I ride them as hard as any other cranks I have used and they are great. I know of several others doing the same with good results. They also allow a much lower Q-Factor than wide ATB cranks, which I like a lot.
Only problem with 130mm road cranks is the large BCD meaning you can only run 38t or bigger. Not a disaster, but makes for some unusually large rear cogs.
JMH
Hi Fred -No i'm not. I am from Finland. Far far away from Springfield...Fast Freddy said:Hey Pekka - are you from Springfield- I know of a guy who has that same name from Springfield.
Later
Fred
I have run ultegra octalink cranks on my cross check for 3 years, no troubles. BB is similar to xt octalink. I have heard several horror stories about the octalink DA BB though. Lighter then ultegra, but not sealed, and needs attention fairly often, or early replacement. I race cross in the Seattle area, so I think that 3 years with no troubles so far is pretty good. They come in two different lengths, If you need more stay clearance the longer tripple BB might work. The double bb works fine on my crosscheck.PekkaP said:I think i'll go with standard 39t ring. 19t in back. BB worries me a bit. I have to use Ultegra bb. Is that good and strong enough?
Top Pro roadies can put out 1800+ watts in a sprint. If a crank can handle that, it can handle anything XC riding is gonna dish out.mrbiggel77 said:Its a road crankset for a reason, Personally I wouldnt risk screwing my nice shiny new DuraAces
