i know its a weird question but are you bending your elbows when you are in the drops? It could be your position on the bike. and the last thing you said is probably a big factor... experience is key.
Classic low side when the front wheel loses traction. That one were the guy high sides in front of Lance and he has to go off road and down to get back on the road is a good one too.chiplikestoridehisbike said:how not to corner
this is perfect. i might add practice the countersteer on a slightly downhill grade, no corners. get a feel for how quick the bike will turn based on different pressure. it is usually faster than you think, which changes how and when you apply the countersteer in corners. like technical rocky mtb downhills, it might take a few tries but when you get it, the ah ha moment is awesomeBenno said:Some quick tips.
-Place your weight on your inside arm and outside leg.
-Outside leg down.
-Brake in a straight line. If you need to slow down do it before the corner starts. Do not touch the brakes mid corner if you are railing a turn.
-Stay outside on the entry of the corner longer than you think you should. This way you are not diving to the apex too early and missing it.
-Relax your upper body but keep a firm grip.
There's a link from that leelikesbikes page to the "Red Bull Road Rage". The text is only in German or French but there are some good pictures and videos. It sounds fun.ebarker9 said:
Please, please, please do NOT raise yourself off the saddle when cornering, not even a little bit. It requires a tension of the outside leg to do so and the resultant stiffness will make everything about the turn screwed up. I've seen folks corner like that, and I guarantee you once I were to recognize someone as cornering that way, I would NOT ride behind them.granpa said:get slightly off the seat so you can lean the bike...not your upper body
corner on the brake hoods till your ready to get back to the drops
I'm hoping this was tongue in cheek sarcasm?granpa said:get slightly off the seat so you can lean the bike...not your upper body
It also enplanes what counter steering is, how to brake in a state line before you start your turn, Other then there being no engine its actually vary similar.jrcxu said:Do what Benno said.
And don't get Twist of the Wrist to learn how to corner on a road bike. The only thing that would be helpful for is picking lines...nothing else is similar (other than the whole 2 wheel thing).
Oh and do what Benno said.
