Anyone else had similar problems? this is my 1st Cannondale, but never needed to replace suss parts on my other rides in such a short time...
No need to Excuse yourself, i guess i was not so clear,. Its the lower bush that mounts the rear shock to seat stay link pivot (see pic). it developed about 1 or 2 mm of play in it.. Im worried that if it need to be replaces in 2 months of moderate riding, it will need to be replaced 6 times a year !!Tuff Gong said:Excuse my ignorance but exactly what part are we referring to when you say 'shock bushes'?Something inside the Lefty or is it some part of the rear swing arm?
I've got a Rize 3 that has about 150 miles on it but I don't think there's any play in it. I haven't hit huge jumps or anything but I do pummel through lots of rocky terrain here in PHX.
I often checked they were all tight, they always were. But i really hope that the wear has been due to this..cdalemaniac said:Maybe it wasn't properly torqued to begin with so now it's shot.
It's not normal for any part to wear out that fast. :nono:
Or in....your armpits? :lol: :lol:ccaddy said:Just to make it clearer , the part in question is a bushing , not
a bush .
Those are in your yard . :thumbsup:
I think you will find that " Bush" is perfectly acceptable.ccaddy said:Just to make it clearer , the part in question is a bushing , not
a bush .
Thanks for the Info. My bike shop said something along the same lines about the parts being Fox. I have fitted a 3rd party Bush and hoop that are said to be also stronger and harder wearing, lets see how i get on with these.. Hopefully the 1st set of bushes were just faulty.rvmdmechanic said:As a mechanic... i don't care what you call it haha...
but you should note that these bushings are not always made by the bike manufacturer, indeed, they are more likely from Fox, since fox only makes one kind of mounting point for its shocks - i would not blame cannondale for this but perhaps you got a bad bushing or it just wasn't put in there right, etc.
but no, many drops, a few bottom-outs and much riding - no such problem. not even a hint of looseness on any pivots.
Replace it and ride on!
More info on this thread..Vasiliyg said:I have the same problem with my Rize One.
Can somebody say if putting the shock in opposite side will help?
thanks for the link... seems like the only solution is to replace those bushes? Can I leave it as it is? will it influence somehow on bike performance?chick0 said:
If i was you, i would have the worn parts replaced as soon as possible, as you don't want to risk damaging your shock or frame mounts.Vasiliyg said:thanks for the link... seems like the only solution is to replace those bushes? Can I leave it as it is? will it influence somehow on bike performance?
I've got slack in mine, but it's on a RZ120, it has done A LOT more miles than you, i do about 100/wk, so it's easy got 1000miles on it now.chick0 said:If i was you, i would have the worn parts replaced as soon as possible, as you don't want to risk damaging your shock or frame mounts.
Could you tell me what size you ordered, as i don't see Cannondale on there bike chart.Anthony6 said:I've got slack in mine, but it's on a RZ120, it has done A LOT more miles than you, i do about 100/wk, so it's easy got 1000miles on it now.
I've not bothered re-ordering a bush, mate whose an engineer hates bushing!, I've ordered 2 of these: needle bearings pivot kit They are 1/2" needle bearings, near identical to the main pivot on my old 68mm Scalpel, so they will take the abuse since they're now on the lower eye compared to the main pivot.
Still waiting for them to be delivered, will let you know when they do. See this thread for more info also Sloppy Rize 5...
