1 - 5 of 5 Posts
This is Hutchinson's tire sealant, their version of Stan's. The stuff is a rip-off. The volume of the bottle isn't labeled but according to the 10 ml. measuring marks on the bottle, it's about 110 ml. The label says you're supposed use 70 ml for a 26x2.00 tire which means you need to buy two $18 bottles to do a set of tires. Stan's, by contrast, is $19.00 / qt. or 960 ML.
Do It Yourself
Think of being back on the trail in less than a minute after getting a flat in a big race. At $15 a pop (at my lbs), seems like the only time it's practical. It would suck to deploy the sealant only to find out you had a sidewall tear. DOH!!!
Premium Member
Protect'air is the flat preventative fluid. Put in and forget.
Fast'air is the inflate and seal on-trail repair stuff (seals up to 1mm hole).
1 - 5 of 5 Posts
