So I just got a new V2 and love it. One issue though, tire clearance. Ibis states it has a max capacity of 2.6. I put a 2.6 Rekon out back and I have quite literally 3mm of clearance from the center of the tread to the inside of the swing arm. Width seems to be ok, but the height! As you can imagine, after one ride just a few rocks was all it took to scrape the hell out of that Carbon to reveal this issue. I have a DHR2 2.4 that has a height of 4mm shorter. That’s still really tight I’m running the stock S35 wheels. The width seems like it’s got adequate clearance with both, but this height issue is really a shocker. You’d think a company that was at the forefront of the wide rim movement and supplies them as OEM would make their frames have plenty of clearance for large volume tires. Doubtful it has anything to do with it, but both tires are the tan wall. I would assume the height from tan to black would be the same, but who knows if there’s a quirk there.
Has anyone else had this height issue? I put some lizard skin frame protection at the tight spot to hopefully prevent further damage.
Im thinking about selling the wheels since the POE suck anyway and getting some Bontrager Line 30 Comps that are a bit narrower and have 108 POE. Cutting down on the ID will almost certainly decrease the volume a bit to help with this issue.
Anyone else have this issue?
-Drew
-Drew
