What size bike and size crank arm. I have a large and it came with 175mm cranks. I swapped them out for 170mm and not I hardly get strikes.Sonicreducer....another 200!!!!Yeah! Do you ever have problems with pedal strikes?
Maybe I have something backwards? 220# ride weight. Here is the history. I started with 2pos/1neg spacer.....rode for months trying to get into shape....not worrying about tune.....When I started to climb/descend more I then noticed pedal strikes when climbing...and descending .....had to be real careful of placement. I added more air to 240psi. Better. DVO suggested because of heavy weight I should add a spacer to neg side....so 1pos/2neg. Much better...less strikes and climbed better....like my energy was going forward not sinking. Rode like that for a few months....sat on other bikes and noticed how cloudy they felt.....I liked how the bike felt when I moved spacers from pos to neg.....realized that I couldn't fit more than two spacers in the neg....so I left the pos out...now at 0pos/2neg......felt very cloudy and smooth on the small vibrating trail I rode that day. The climb felt different....not as easy. The next ride was more difficult tech climb/down....did not feel very good on the way up....way more noticeable than on the non tech climb the day before.....I ended up moving the switch to the climb position just to make it feel like I was getting forward momentum. I don't do big jumps or drops....would like to....and never get close to using all my travel. I think I'm only at 14mm sag. I think the high psi is keeping me from using more travel....not needing spacers in the pos...I wonder if there is a half size spacer to fit in the neg side.....I think there is a bit of room.
main=240psi
bladder=200psi
rebound=5 clicks maybe too much?
spacers=0pos/2neg
