These are showing up at dealers this week. I think this is a great idea to get a quality bike at a lower price point.
- 29” Wheels
- 160mm front travel
- 147mm dw-link rear travel
- 2.6” tire clearance
- Aluminum front and rear triangle
- Available in four sizes S-XL, fits riders between 5’ and 6’6
- Frame weight of 8.25lbs for a medium with a DVO topaz shock
- Available with DVO JADE X coil shock
- Progressive suspension leverage ratio for compatibility with select coil shocks.
- Slack 64.9 head angle
- 44mm Fork Offset
- Steep 76 degree seat tube angle
- Threaded BB (73mm BSA)
- ISCG 05 Compatible with removable adapter
- Port style Internal cable routing
- 22oz bottles fit inside front triangle
- Size M-XL compatible with 170mm+ droppers, 125-150mm for smalls
- Molded rubber swing arm protectors
- IGUS bushings in lower link, bearings in upper link
- Metric 210x55 shock
- 203mm max rotor size
- 1x specific design
- Boost spacing
- Tapered headtube and steerer: ZS44 upper, ZS56 lower
