Hi all,
I've been dealing with some creaking from my Riot for awhile. After extensive troubleshooting I'm about at wits end - I've tried a laundry list of things and nothing has worked. The creak seems to be coming from around the BB area or from the rear triangle/hub. It occurs whenever pedaling hard or applying significant torque through the pedals. It happens both in and out of the saddle. I haven't really noticed it when coasting. It sounds about like crushing an empty disposable plastic water bottle with each pedal stoke - very loud and very annoying.
So far I've:
Rebuilt both front and rear hubs with fresh bearings (this spring)
Replaced rear hub end caps, one was missing an o-ring which allowed it to move (this spring)
Removed chainring and checked its interface to the crank (this winter)
Removed cranks and checked fit (this summer)
Checked bottom bracket for wear or play (this summer)
Fully rebuilt linkage with new bearings (this summer)
Serviced suspension, replaced rear shock bushings (this summer)
Tried different sets of pedals (this summer)
At this point, I'm not sure what else to do. During my last ride the creaking was especially bad - it sounded like someone was stomping on the plastic bottle. Since Canfield doesn't supply any torque specs, I've just been tightening up the shock bolts and the rear axle until solidly tight, using two fingers on a 6-inch hex key.
I would greatly appreciate any help/suggestions. This creak has been bugging me for months, I would love to silence it.
So far I've:
