For my Downhill riding I have always appreicated a larger tire (FRONTS: 2.7 Nevagal DH, 2.7 Minnion DHF, REAR: 2.35-2.7 similar model) for the bigger footprint, increase in traction. The bigger tire sucks however on rims with a "narrower" width, as you get a "floppy sidewall", increased pinch flats at lower pressures.
SO: I am considering a tubeless setup this season, mainly to (slightly) decrease rotational mass, increase traction/tire performance. Mainly, I want to run a lower pressure without the pinch flat problem and my tires ALWAYS slipping on my rim (thus turning my tube and messing with my air stem).
1) Is my solution a Crank Bros SAGE or OPIUM wheelset w/STANS? Are they wide enough at only 24mm internal width? Will the tire slip on the rim under hard braking?
2) If not, is my solution a super wide rim on a good 150mm hub and a Stans tubeless kit? Will sllippage be a prob?
3) Just freaking SuperGlue my tire to rim??
SUGGESTIONS please....
