1 - 3 of 3 Posts
Salsa states on their website that the Mamasita's geometry was measured using the 80mm Reba with 15% sag. So if an unsagged 80mm Reba has an Axle-To-Crown of 490mm, it would have an A-C of around 416mm if it was sagged 15%.
White Brothers offers the Rock Solid rigid fork in three lengths: 425mm, 445mm, and 465mm.
Just wondering what the recommendation is. Thanks in advance for any input!
Amount of sag should be taken off the travel length instead of a-c. You should deduct 15% of 80mm off the a-c length. The 465mm one should be the one to go if you want to retain the geometry.
Premium Member
The spec chart also shows a fork length of 468mm with 39mm of offset.
1 - 3 of 3 Posts
