Hi,
I do ride a 5 Spot so am "legit" on here
Anyway, I have a technique questions. Could have posted on the DH board, but folks on here seem to be much more responsive and mature, at least my perception.
Okay, when riding down steep chutes, I am learning how to let it go in the tough sections and then brake where there is opportunity, but what about corners on steep chutes?
What I want to understand, and learn how to do is use that kind of "rear wheel steeering" rudder effect, with control. I sort of do it now, but it's without total control.
I was coming down a reasonably steep chute yesterday and was going pretty good actually, then came upon the turn and wasn't able to make the turn, so had to dismount, remount, then ride the rest of the section.
I've seen Steve Romaniuk do this technique in The Collective while going super fast, and I've seen it down in one or some of the Kranked films, with the Fro's riding down some long loose, steep mountain.
Any help to where I can understand the technique in my mind would be appreciated.
Also - and related, on non banked, flat corners going fast on singletrack, how do you inititate the rear slide so that it points you in the right direction, rather than having to brake? How do you practice this technique? (some info says practice in a dirt parking lot just ride straight then say to throw the tail left, turn the bars left just for a sec, then hard right and try to weight the inside right grip and toss the tail around with hips?
I can do this a bit more than 90deg or maybe close to 180 deg one way, but it's harder the other!
