Hi guys
after a rather rough landing while jumping, i discovered my headset was loose(knocking noises in the headtube while rocking the bike back and forth, front brake engaged ).
after tighening it, the problem was resolved until two rides later where the headset loosened again (the jump and drops were small 3 foot at most).
1) trawling through previous posts, one opinion offered was that the star nut had loosend on its own. besides this are there any other possible causes and solutions to this problem?
in addition i discovered that there was some knocking (inaudible but can be felt through the bars)coming from my fork itself(dual crown). this can be felt mostly on the lowers and the section where the stanchions enter the lowers but is not readily detected on the stanchions esp those furtherst from the lowers.
2) is what i've described above play in the fork and if so is it due to worn or damaged bushings?
Thanks in advance!
Thanks in advance!
