<p>I've got opurtunity to inspect very promising dual led bicycle light from Kaidomain.com.</p><p><a href="http://kaidomain.com/bike-lights-and-bike-accessories/Bike-Lights/KDLITKER-Bike%20Lights/KD-2-x-Cree-XM-L2-U2-4-10-Mode-2200-Lumens-Bike-Light"><img src="http://kaidomain.com/image/cache/catalog/Bike%20light/S023788-1-458x599.jpg" height="200" width="150"></a></p><p><a href="https://www.kaidomain.com/p/S023808.z">https://www.kaidomain.com/p/S023808.z</a></p><p><span class="CategoryHeadline">From the outer look it is the one of few latest clones of Yinding (Gemini Duo clone), so it is essentionaly clone of the clone. <img src="/sites/all/libraries/tinymce/jscripts/tiny_mce/plugins/emotions/img/smiley-wink.gif" alt="Wink" title="Wink" border="0"></span></p><p><span class="CategoryHeadline">Here are the pictures:</span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/2b/Vp/27m8vQ4s/p1040328.jpg" height="342" width="512"></span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/20/134/354qEYR5/p1040331.jpg" height="342" width="512"></span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/V/pv/2RPYhgeh/p1040334.jpg" height="342" width="512"></span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/2n/J5/49u2GWsW/p1040336.jpg" height="342" width="512"></span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/22/qX/18gTcTTq/p1040338.jpg" height="342" width="512"></span></p><p><span class="CategoryHeadline"><br></span></p><p><span class="CategoryHeadline">Taking it apart was quite easy</span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/2A/GH/1qdiJ3nD/p1040357.jpg" height="342" width="512"></span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/2I/4C/3PWmCfps/p1040365.jpg" height="342" width="512"></span></p><p><span class="CategoryHeadline">The driver:<br></span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/G/11V/wgRKA6W/p1040359a.jpg" height="313" width="512"></span></p><p><span class="CategoryHeadline"><br></span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/2d/SM/39oqIwEi/p1040372a.jpg" height="329" width="512"></span></p><p><span class="CategoryHeadline">Internals - PCB:<br></span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/2S/tn/153SUcSV/p1040377.jpg" height="342" width="512"></span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/3x/lT/1XIzxN5n/p1040381.jpg" height="342" width="512"></span></p><p><span class="CategoryHeadline">Lenses:</span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/3z/vI/2oN5vTr6/p1040383.jpg" height="342" width="512"></span></p><p><span class="CategoryHeadline">Lenses can be simply replaced:<br></span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/3V/hZ/279slZoA/p1040397a.jpg" height="338" width="512"></span></p><p><span class="CategoryHeadline"><br></span></p><p><strong><span class="CategoryHeadline">Opearating:</span></strong></p><p><span class="CategoryHeadline">The light has three modes chosen from 10 brightness levels. It can be any combination you want. You can make it Low, Mid , Hi or Hi, Mid , Low or Low, Hi, Mid if you want. For this test I've choosen levels 1, 4 and 10. Strobe is hidden and can be reached with long press from off mode.Light is turned off by long press in any mode. </span></p><p><span class="CategoryHeadline">The light is powered by tipical 2S2P 8.4V battery pack.<br></span></p><p><strong><span class="CategoryHeadline">Power usage</span></strong></p><p><span class="CategoryHeadline">Connected to the battery pack:<br></span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/3b/11Q/3wvAYDEy/level0.jpg" title="Connected to the battery pack" height="342" width="512"></span></p><p><span class="CategoryHeadline">Level1:</span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/2I/nd/3Q6ngarI/level1.jpg" height="342" width="512"></span></p><p><span class="CategoryHeadline">Level4:</span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/3A/Ea/2YfX5ZqU/level4.jpg" height="342" width="512"></span></p><p><span class="CategoryHeadline">Level10:</span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/3g/5v/3aIJ5VSS/level10.jpg" height="342" width="512"></span></p><p><img src="http://shrani.si/f/1Y/2U/22EMN6fs/power-to-the-leds.jpg" height="284" width="640"></p><p> </p><p><span class="CategoryHeadline">Beam on high:<br></span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/18/XJ/29maNsJq/p1040411.jpg" height="342" width="512"></span></p><p><span class="CategoryHeadline">Beam of 2nd generation Yinding to compare to:<br></span></p><p><span class="CategoryHeadline"><img src="http://shrani.si/f/I/MZ/4RudDHde/p1040410.jpg" height="342" width="512"></span></p><p><span class="CategoryHeadline"><br></span></p><p><strong><span class="CategoryHeadline">Final verdict</span></strong></p><p><strong><span class="CategoryHeadline">Pro:</span></strong></p><ul><li><strong><span class="CategoryHeadline">best user interface you can find in the budget bicycle lights</span></strong></li><li><span class="CategoryHeadline">10 levels of brigtnes to choose from<br></span></li><li><span class="CategoryHeadline">small and very light</span></li><li><span class="CategoryHeadline">nice evenly spreaded beam</span></li><li><span class="CategoryHeadline">overheating protection</span></li><li><span class="CategoryHeadline">XM-L2 U2 leds (despite title says it's XM-L)</span></li><li><span class="CategoryHeadline">14.5W (2200mA) to the leds</span></li><li><span class="CategoryHeadline">possibilities to exchange TIR lenses for wider angle<br></span></li></ul><p><span class="CategoryHeadline"><strong>Con:</strong><br></span></p><ul><li><span class="CategoryHeadline">not the best heat transfer to the housing (Yinding has it much better)</span></li><li><span class="CategoryHeadline">no thermal paste (as usuall, but can be easily added)<br></span></li><li><span class="CategoryHeadline">can overheat at higher levels but it's ok when moving fast<br></span></li><li><span class="CategoryHeadline">cool white leds (neutral white would be much better)</span></li><li><span class="CategoryHeadline">not waterproof but can probably stand light rain</span></li></ul><p><span class="CategoryHeadline"><br></span></p><p><span class="CategoryHeadline">Overall very nice bicycle light for helmet use, specialy for MTB purposes. There are quite some improvement I would like to see, though.<br></span></p>
