Five Ten's new Maltese Falcon LT all-mountain shoes bring lighter weight, better water resistance and a good blend of sole stiffness-to-hikeability to the substantial feature set of its predecessors. Already known for superior durability, comfort, and clipless compatibility-not to mention the always sticky Stealth S1 rubber soles-the new, $140 Maltese Falcon LT's show Five Ten is keeping a finger on the pulse of the sport and developing product accordingly.
Five Ten Maltese Falcon LT Top
Tough, sticky and balanced
The Maltese Falcons use a synthetic textile upper for improved durability, abrasion and water resistance, and quicker drying. A waterproof toe cap, along with two Velcro straps cover the laces and help prevent the entry of water and debris.
While most riders will run the Maltese Falcon's in clipless mode, their grippy Stealth S1 rubber outsole is sticky enough for use on flat pedals as well-though we'd recommend a dedicated pair of shoes for serious flats riding. Our point is that the grippy outsole also makes the shoes sticky on rocks, logs and roots, even when wet. It also provides cushioning for hike-a-biking, and damping while banging down the trail, all of which increases comfort and reduces fatigue.
The moderately stiff shank provides good power transfer to the pedals, but still retains good sensitivity and flexibility for walking. It has a tall and thickly-padded collar and heel cup to keep the foot firmly locked into the shoe. The tongue has ample padding for instep cushioning, while the dual hook-and-loop Velcro closure system, along with the laces, provide wide-ranging adjustability for good fit.
Five Ten Maltese Falcon LT Sole
Easy set-up, great on-bike performance
Unlike other shoes which require heavy equipment to get at the clip mounts, removing the Maltese Falcon's covers only required some needle-nose pliers and a steady pull. Our SPD's clips went on without a hitch and required no extra trimming to clear the pedals. Click-in was positive and definite, and the sticky Stealth rubber added to the grip on our wide-bodied Shimano XT Trail pedals.
In rocky and technical terrain, where you regularly hit and bang into things, the thick toe box, sides and tough uppers, offered excellent protection for the entire foot. The synthetic textile uppers shed mud, water and dirt, helping to keep your feet dry and clean.
Because the shoes are so tough they do give up a bit of breathability, but we never found them oppressive, even on the hottest days.
Five Ten Maltese Falcon LT Flex
All-mountain-tuned sole, functional looks
The sole was surprisingly stiff for a trail shoe and provided good pedaling performance, yet it had enough flexibility that it made walking and hiking forgiving. It's not an ultra stiff cross-country shoe, but the blend of power and flex are optimal for a shoe in this realm.
As looks go, Five Ten went with functionality over fashion on the Maltese Falcons. They look more like slippers than cool kid skate shoes, but we don't really care-we're here to mountain bike, not pose.
Five Ten Maltese Falcon LT Side
Bottom Line
The Five Ten Maltese Falcon LT clipless shoes offer superb protection when riding and walking down gnarly terrain, helping to protect the feet from close encounters with rocks and trees. The new waterproof toe cap and dual Velcro closure help keep the feet drier and cleaner, though a fully attached tongue would improve their resistance to contaminant entry.
The uber sticky Stealth S1 rubber outsoles give excellent grip and traction on rocks and obstacles, allowing easy mobility on technical terrain, though the lugs likely aren't tall enough for digging into deeper mud. The shank offers good stiffness for pedaling as well as flexibility for hiking. While slightly heavy at 980 grams per pair, the shoes offer up incredible armoring and water protection in return. Though the uppers are very tough, they aren't the most breathable.
The Five Ten Maltese Falcon LTs are a good, comfortable, secure, durable and protective all-mountain shoes with sticky soles and a moderately stiff and flexible shank.
Pros
  • Sticky and shock absorbing Stealth S1 rubber sole
  • Protective toe box, sides and uppers
  • Waterproof toe cap
  • Good compromise of stiffness and hikeability
  • Wide dual Velcro closure strap
  • Nice heel cup and padded cuff
  • Durable, especially the abrasion-resistant upper
  • Clipless or flat pedal compatible
Cons
  • Not cross-country stiff
  • Needs a fully attached tongue
  • Lug height not the best in mud
  • Not the most breathable
  • Heavy
Weight: 980 grams (pair, size 9)
MSRP: $140
More info: fiveten.com
