I am still trying to get my head around how much extra front wheel height I would be dealing with in different setups on a 2018 SD. The fork ATC numbers look pretty close (+/- ~2mm) between 27.5 170mm and 29er 150mm fork so that is promising.
As far as for the front wheel itself, I found the below numbers over at
https://www.bikecalc.com/wheel_size_math; for those of you with 29er wheels do you think these are accurate within a few mm? I would like to keep running my rear wheel as a minion DHRII, current size is 2.4, and I could run a larger rear but I don't think I want the rear wider than the front so somewhat stuck there.
So far the best I can come up with in terms of minimizing the change in height of the front end in this setup is a 2.4 29er on the front, keeping 2.4 rear which according to these numbers would leave me with an extra ~16mm of front-end height in the mullet setup.
Wheel size Wheel diameter
650b/27.5 2.40 inch 705.92
650b/27.5 2.50 inch 711.00
650b/27.5 2.60 inch 716.08
700c/29er 2.30 inch 738.84
700c/29er 2.35 inch 741.38
700c/29er 2.40 inch 743.92
700c/29er 2.50 inch 749.00
