1 - 5 of 5 Posts
Just rebuilt my Revelation U-Turn, orings looked fine, so I didn't replace any. Put it back together, and when pumped to spec with pos and neg air chambers the same (150psi for 185lbs), the fork is sitting around 135mm with U-Turn fully extended. Dropping the neg pressure to around 110psi gets the fork back to 150mm. Can't say for sure whether or not it acted like this before I pulled it apart. Whats going on?
If you have the + and - chambers to close to the same PSI, the fork will 'suck down' and you wont get full travel. I believe the most popular way to set-up these dual air U-turns is to pump the + chamber to desired PSI and then add ~5-10 psi LESS in the - chamber. If you watch your fork when you are pumping up the - chamber, you can actually see the point where it begins to 'suck down' in its travel.
I just rebuilt my wifes dual air u-turn, as it was losing air from the upper chamber and thus losing full travel. It seems to be fine after the rebuild so far...
Good luck!
What he said.
And 150psi sounds high. I'm the same weight and I run much less air than that. How far are you sagged in?
mk
Discussion Starter · #4 ·
Just went off the pressure charts. I'm about 185-190 all geared up, 175 naked.
Seems to have normalized somehow. Felt decent around the neighborhood. Wondering if its my **** shock pump. Gonna try other ppls.
The pressure charts on RS products are wrong. I am not sure where they come up with those figures. You should be setting your pressure based on sag, not on what the charts say. Aiming for around 25% sag is a good start.
1 - 5 of 5 Posts
