1 - 4 of 4 Posts
· Scott is a tool.
Hey,
An unusual desire indeed, but the reason i'm asking is because i want to put this fork on a Yeti ASR-5, and the max fork travel is 140mm for that frame. I could get the fixed travel Revelation, but i want to be able adjust the head angle as i please.
So, can you put a spacer in the U-turn models, as you can in the fixed travel models?
Cheers,
Grant.
· Scott is a tool.
Discussion Starter · #3 ·
erosive said:
...that little knob on the left leg... turn it two times clockwise.
problem solved, and you didn't even pay a cent!
Um yeah, i'm aware of that feature, but that wasn't the point of my question. I don't want to void the warranty of still having the 150mm fork on the frame, even though i'm not using the full amount of travel.
Cheers.
· switchback sculptor
you can't add a spacer, but i think you can swap this in...
DualAir spring assembly, 09 Revelation (140mm)
bti part #RS-3969
I would personally just ride it stock though.
I've never had to send in the fork when waranteeing a frame.
1 - 4 of 4 Posts
